Problems with Quartz Composer and Audio In
  • _blank
    by _blank » Mon Mar 24, 2008 3:19 pm
    I have problems with Quartz Composer files with Audio In, I can import the files to modul8, but there isn't any reaction to sound... In fact, if I open the files in Quicktime Player they don't work either, any idea?
    wygiwys
    by wygiwys » Tue Mar 25, 2008 9:39 am
    Do you've got Leopard?
    What You Get Is What You See
    WYGIWYS.tv
  • _blank
    by _blank » Tue Mar 25, 2008 10:02 am
    Yes, the computer is new
    wygiwys
    by wygiwys » Tue Mar 25, 2008 4:02 pm
    Here's the problem:
    Any of you who do use quartz compositions in your visuals who haven't yet upgraded should be aware of a major change in the system.
    All quartz compositions exported through the quicktime player (or simply opened as is in modul8) are forced to run in a new "safe mode" which basically disables a whole lot of important patches that can pose a security risk on the system.
    Among them, Audio Input is disabled. MIDI input is disabled. ALL 3rd party plugins are disabled. There is no "disabling" safe mode either.
    I've been following discussion on the QC mailing list and apparently the only way to get these functions (I'm aware of) back is to "wrap" these patches in a plugin and then use a hack to make 3rd party plugins pass the safe mode. This of course opens up your system to major security vulnerabilities.
    In short, upgrading has totally f.... me. I used audio input and midi in quartz comps a lot. The only reason I upgraded to Leopard in the first place was to be able to take advantage of the new version of QC, and now I find it's basically useless. There is no mention of this new safe mode in the Quartz release docs, I guess I should have researched more.
    Adam
    WYGIWYS.tv
  • _blank
    by _blank » Wed Mar 26, 2008 12:10 pm
    I've discovered a plugin that solves the problem :)
    http://kineme.net/QuartzComposerPatches ... oInput/0.1
  • mowgli_uk
    by mowgli_uk » Thu Mar 27, 2008 1:44 pm
    Does anyone know a solution for this in Tiger??
    wygiwys
    by wygiwys » Thu Mar 27, 2008 6:42 pm
    Tiger isn't supposed to have these problems, because the 'safe' thingy only comes in quartz composer in Leopard...
    WYGIWYS.tv
  • mowgli_uk
    by mowgli_uk » Thu Mar 27, 2008 6:53 pm
    I'm talking about the fact that whatever you do quartz files or exported mov's always default to mic rather than line in when reopened
  • r4f0
    by r4f0 » Wed May 14, 2008 11:08 am
    Cool answers. But what about the midi and mouse controlled patches? there's any plugin to do this or have to do manually inserting them in a third party patch? Any ideas?
