edirol v4
  • sisteray
    edirol v4
    by sisteray » Sat Apr 05, 2008 9:20 pm
    I am having problems to view, in the preview monitor output, my computer running modul8 through the Edirol v4
    How can i see what is running on Modul8 on my preview monitor, with the Edirol V4 Mixer?
    Many thanks.
    Francesca
    by sigmasix » Sun Apr 06, 2008 9:41 am
    plug your preview monitor on the preview plug, top right, next to the outputs. Then you have button on the left of that plug, you can choose to view the inputs seperately, or the output.
  • Lando
    by Lando » Sun Apr 20, 2008 11:41 pm
    or if you're using a DVI to VIDEO/S-VIDEO adapter cable.. you can use the two output working together.. for example the s-video goes to the V4 and the component video goes straight to the preview monitor.. so you can have indipendent preview monitor straight from your mac. and maybe have another preview monitor for MASTER PREVIEW straight from your V4.
    this is what we do when we are playing with two macbookpro and a V4. we are using 3 lcd preview monitor.. one for each MBP adn one for v4 (MASTER PREVIEW)
    just give it a try
    lando
