PureData, OSC and Keywords
  • fernan.izquierdo
    by fernan.izquierdo » Tue Apr 08, 2008 3:08 pm
    Hi all,
    I am quite a newbie with all this stuff, but I'm trying to send some OSC from Pure Data to Modul8, so the steps I've followed are these:
    1. Add the OSC(global) library to MD8.
    2. Send OSC messages to my own IP with the data.
    3. MD8 receives the message and is able to see it, for instance, I get this message at the script output window:
    RECEIVE : ['/md8key/crtl_layer_alpha/0', ',f', 0.5]
    However, nothing happens!! I've tried with different keywords but nothing....what am I doing wrong?
    Thanks a lot guys.
    Fernán.-
  • julbel
    by julbel » Sat Apr 19, 2008 12:00 am
    ok i try and it's ok :
    You have to put in PD :
    send /md8key/ctrl_layer_alpha/1 0.2 for example.
    And it's change your alpha channel in Layer 1 : i put a simple documentation soon.
    i can send you the pd patche if you want :
    Code: Select all
    #N canvas 285 312 821 543 10; #X obj 56 344 sendOSC; #X floatatom 56 371 5 0 0 0 - - -; #X msg 41 67 disconnect; #X floatatom 110 373 5 0 0 0 - - -; #X text 159 376 bundleDepth; #X text 5 90 comment; #X text 24 11 SEND OSC to MODUL8; #X floatatom 266 328 5 0 0 0 - - -; #X msg 63 93 connect 82.224.255.125 32000; #X msg 52 124 connect 192.168.0.6 32000; #X obj 327 169 r rand1; #X obj 400 201 r rand2; #X floatatom 355 293 5 0 0 0 - - -; #X msg 24 40 connect localhost 8002; #X msg 357 321 send /md8key/ctrl_layer_alpha/\$1 0.2; #X msg 267 357 send /md8key/ctrl_layer_alpha/\$1 0.6; #X obj 333 52 cnv 15 160 90 empty empty empty 20 12 0 14 -24198 -66577 0; #X floatatom 363 56 5 0 0 1 amount - -; #X msg 407 100 1 1 1; #X msg 392 76 3 2 1; #X obj 334 122 scale 0.5; #X msg 411 269 send /md8key/ctrl_layer_text_field/\$1; #X msg 477 217 testet; #X obj 593 80 dumpOSC 8000; #X obj 601 114 print; #X connect 0 0 1 0; #X connect 0 1 3 0; #X connect 2 0 0 0; #X connect 7 0 15 0; #X connect 8 0 0 0; #X connect 9 0 0 0; #X connect 10 0 7 0; #X connect 11 0 12 0; #X connect 12 0 14 0; #X connect 13 0 0 0; #X connect 17 0 20 1; #X connect 18 0 20 2; #X connect 19 0 20 2; #X connect 21 0 0 0; #X connect 22 0 21 0; #X connect 23 0 24 0;
  • fernan.izquierdo
    pd osc
    by fernan.izquierdo » Sat Apr 19, 2008 12:58 pm
    thanks very much, i finally managed to get it working :)
    thanks thanks
    G4jima
    by G4jima » Tue Jun 03, 2008 12:16 am
    where do I put this code guys? please help i too am almost there!
  • selrach
    by selrach » Fri Jun 20, 2008 11:10 am
    hello, excuse my english :)
    i try to use OSC too, from pd to modul8.
    i can see that md8 receive information(on the screen output) when i type in pd /send /md8key/ctrl_layer_alpha/1 0.2 or when i use the patch up,
    , but there is not effect.
    and if i move something in md8, i can see information on pd window.
    So where is my error ?
    thank you to help me
  • selrach
    by selrach » Mon Jun 23, 2008 11:40 am
    up :D
    by vanakaru » Sun Aug 24, 2008 12:58 pm
    I got hooked on iPod touch controlling M8 last week. I used ITM apps, but OSCemote seems to be the tool I really need.
    Almost a week I have tried to figure how to get it to work in M8. I am almost ready to give up. I am not a programmer, just the opposite. I like the intuitive control via ipod and hate setting up computers.
    I have read all the articles about OSC to MIDI and direct to Modul8 and tried what i understood, but no results.
    Could somebody explain step by step so my old visual artist brain could get it too. Thanks!
