deauthorization troubles...
  • martamarta
    by martamarta » Tue Apr 22, 2008 10:17 pm
    I've accidentally deleted my former modul8 version without deauthorizing it before installing the new one...is there something I can do?
  • spectral
    by spectral » Wed Apr 23, 2008 7:29 pm
    if it is the same piece of hardware just re authorise it will not use up any more authorisations as modul8 uses mac address of computer i believe.
    Whenever i install a new version of M8 it asks fro serial and for authorisation.
    If it is a new piece of hardware and you did not de authorise the old machine then you will have to ask support at garagecube dot com what to do.
    You can have M8 installed on two machines on a single licence version.
