length & size of quartz comps
  • bAjA
    by bAjA » Sun Apr 27, 2008 7:45 pm
    is there any way to change the default length and size of quartz compositions when loaded into modul8..?
    at present they show in the inspector as 30sec & 640x480..
    my main issue is that my generative partners restart every 30 seconds..
    (i realize exporting as quicktime is one solution - but it has its own issues)
    As this is my first post after 12 months of using modul8 and much reference to this forum - a quick thanks to the M8 team & the forum members...
    cheers _bAjA
    rolin
    by rolin » Sun Apr 27, 2008 8:15 pm
    I am afraid exporting as quicktime
    with the desired length and resolution
    is the only solution here and now.
    Because of the fact, that Quartz Composer files always
    restart after a given time (default is 30 sec.)
    this can only be called pseudo generative.*
    Even if I love M8, this is the reason
    why I ogle with VDMX.
    It's the only program with
    proper QC integration at the moment.
    So hurry M8 team ;)
    Cheers,
    rolin
    *also because external audio and video signals
    don't find their way through to the QC clips.
  • bAjA
    by bAjA » Sun Apr 27, 2008 8:41 pm
    ok... thanks...
    i thought VDMX might be the future- but after much testing and excitement at its versatility and quartz integration.. i think m8 wins on speed...
    but without doubt quartz is future... so seconded hurry up m8...
    _bAjA
  • mowgli_uk
    by mowgli_uk » Mon Apr 28, 2008 10:49 am
    I mentioned it on another post, but I back this too.
    MD8 + better quartz integration=very happy MD8 users
Users browsing this forum: No registered users and 58 guests
