I have a few 1 minute clips made with 126 BPM. How can I sync them with the BPM global value?
Right know I'm doing the sync manually with the speed control. Is there another way?
cheers
IncuF
its really a good ideathat work for short clips, I think that a clip should have its own BPM options, so you can tell a clip to fit an x numer of beats.
If you can tell a clip in how many beats it should loop, you can trigger different clips with durations within one layer and everthing will be in sync.
But I gess that would be a request for upcoming modul8 versions
cheers
IncuF
