Mac Pro
    markvideo
    Mac Pro
    by markvideo » Sun May 04, 2008 6:29 pm
    Does any one know if the Mac Pros can handle multiple screen outputs? (Advanced Output)
    ie: No loss of frame rate or quality?
    wygiwys
    by wygiwys » Sun May 04, 2008 7:21 pm
    It can handle multiple outputs, just put some graphic cards in there.
    Depends on your configuration how smooth it'll work. But it's likely to have good performances.
    What You Get Is What You See
    WYGIWYS.tv
    markvideo
    by markvideo » Tue May 06, 2008 2:31 pm
    Thanx.
    What graphic cards would you recommend?
  • RickRobiN
    by RickRobiN » Thu May 08, 2008 3:12 pm
    Hi, This one. http://store.apple.com/us/product/MB198Z/A?fnode=home/shop_mac/mac_accessories/displays&mco=MTA4MzA0
    Works with the Apple Video Adapter for S-Video or Composite video output.(4 outputs max or 8 vga)
    But it's a really noisy card. Fan speed is anoying
    (|BTW I am talking about the mac pro 2008 with with pci-express 2)
    Good luck!
    RR
    markvideo
    by markvideo » Thu May 08, 2008 3:51 pm
    THANX
Users browsing this forum: Baidu [Spider] and 41 guests
