Matrox Dualhead 2 Go + iBook G4?
  • JoelDittrich.se
    by JoelDittrich.se » Thu May 15, 2008 2:38 pm
    Hi!
    I´m planning to use:
    - iBook G4 + Tiger 10.4.11 + QT 7.4.5 (mid 2005, 1.42 Ghz, 1 gig ram, ATI Mobility Radeon 9550 with 32Mb ram)
    - Screen spanning Doctor
    - Modul8 2.5
    - Matrox Dualhead 2 Go
    Did anybody try this set up?
    Think my GPU is to bad/slow?
    Maybee it works if I set the rez kind of low, like 1280x480? (all content is 320x240)
  • JoelDittrich.se
    by JoelDittrich.se » Thu May 15, 2008 10:12 pm
    Their site: http://www.matrox.com/graphics/en/gxm/p ... o/home.php
    Anyway, guess this will be to heavy since:
    "Supported Display Modes
    Resolution Refresh rate
    2048 x 768 60, 75, 85Hz
    2560 x 10241 60Hz"
    ...because it would make M8 work in 2048 x 768?!
    deepvisual
    by deepvisual » Thu May 29, 2008 10:13 am
    you'll find the more vram you have the better the TH2go works. 32 is not a lot at all.
    codec and hard drive also affects playback..
    I use apple intermediate codec and have a f/w 800 external drive for my clips.
    sadly you can't upgrade the Vram on apples.
    rolin
    by rolin » Fri May 30, 2008 12:44 am
    deepvisual wrote:you'll find the more vram you have the better the TH2go works. 32 is not a lot at all.
    Hi Gary,
    what advantage would you say does the apple intermediate codec have?
    I tested it and I aways have to come back to MotionJPG or PhotoJPG…
    Cheers,
    rolin
