modul8.getValue
    modul8.getValue
    by sigmasix » Tue Mar 01, 2005 11:32 am
    Hi, I tried to use modul8.getValue but I don't understand how it works...
    Code: Select all
    getValue(keyframe,value,layer): Returns the value of a Modul8 keyword
    so, if I want to get the modulate colour value of my selected layer I will use something like that
    Code: Select all
    modul8.getValue('ctrl_layer_color_modulateR', ***, 0)
    but I don't know what to write where the *** are... 'value' returns a syntax error and variables are not the solution... nothing is not the solution too...
    so, how does it work? ;)
    thanks
    klebowax
    getValue getNextBetaOfModule8
    by klebowax » Tue Mar 01, 2005 12:20 pm
    I think we have to wait for the next beta release for these options.
    yves@garagecube
    Re: modul8.getValue
    by yves@garagecube » Tue Mar 01, 2005 6:06 pm
    You are right, there is nothing to write in the ***. The correct API for getValue is:
    Code: Select all
    modul8.getValue(keyword, layer) #for instance: modul8.getValue('ctrl_layer_color_modulateR',1)
    Yves.
    by boris » Wed Mar 02, 2005 6:45 am
    Yes Yves, But do not forget, this function does not work into the beta1 & 2.
    :roll:
    Sorry Sigma6, It will work in the next beta.
    by sigmasix » Wed Mar 02, 2005 9:52 am
    ok, thanks ;)
