Video Streaming as input
  • Ogl
    by Ogl » Thu Mar 17, 2005 6:27 pm
    At first, sorry for my bad englih.
    It is possible to catch a video stream (using VideoLanClient to stream webcam sources over a network) ?
    I want to switch between 5 different streams in the same output, so Modul8 seams to be a good solution.
    by sigmasix » Fri Mar 18, 2005 10:47 am
    If you give me your stream's URL I can try for you.
  • Guest
    by Guest » Fri Mar 18, 2005 1:08 pm
    I can't, it's on an intranet. MP4 streaming with VLC.
    How to open a stream as a media?
    by sigmasix » Fri Mar 18, 2005 1:31 pm
    hum... ok... I'm not sure it will work like that.... Modul8 only opens files that QuickTime can open. If you must open your mp4 file in VLC it may not work with modul8... I don't even know if you can add a stream file in modul8... maybe in the future. bye
  • Guest
    by Guest » Fri Mar 18, 2005 4:07 pm
    OK, thanks
    yves@garagecube
    Re: Video Streaming as input
    by yves@garagecube » Fri Mar 18, 2005 7:01 pm
    Ogl wrote:At first, sorry for my bad englih.
    If the stream is encapsulated in a QT file, it *may* work... we did not really test this kind of QT features with Modul8. Download the demo and try to drag your QT files to Modul8 to see if it works.
    Yves Schmid.
  • Guest
    by Guest » Fri Mar 18, 2005 7:08 pm
    Bonjour, vu que vous semblez habiter à Genève je me permet de m'exprimer de français.
    Il me reste donc à trouver un moyen de faire du streaming de fichier QuickTime pour tester cette solution.
    Merci de votre réponse.
