14 bit midi data ?
  • dlf
    14 bit midi data ?
    by dlf » Wed Mar 30, 2005 11:09 pm
    Is it possible in v.1.1.0 to combine 2 midi channels for control ?
    = one for crude control, the other one for fine control
    (btw: using 1.1.0 because i'm using it for a theatre play where it has to run absolutely stable ..
    what's the status on the stability of 2 beta ?)
    /////// www.telcosystems.net ///////
    :: systems for a processed future ::
  • studioc
    by studioc » Wed Mar 30, 2005 11:29 pm
    The beta is about to get pumped up to version 3. Possibly sometime this week. Garagecube says that this will be close to the final revision. As beta 2 is pretty stable, I would bet that if you wait for beta 3, you'll be doing alright. Good luck with your project! 8)
    The Revolution must be televised!
  • dlf
    by dlf » Thu Mar 31, 2005 12:40 am
    ah yes, i should 've mentioned, my deadline is coming saturday :wink:
  • stuart
    by stuart » Mon Apr 04, 2005 10:19 pm
    use 16 channels of pitch bend.
