FPS Display
    Re: FPS Display
    by franz » Tue Dec 11, 2018 6:27 pm
    on mac, type this onto your terminal, then relaunch MM:
    defaults write com.garagecube.MadMapper logFPS 1
    set it back to 0 to remove fps
    on windows type in command prompt:
    REG ADD HKCU\SOFTWARE\Garagecube\MadMapper /f /v logFPS /t REG_SZ /d 1
    at any time you can reset mm to factory defaults, in the file menu
    caneron
    Re: FPS Display
    by caneron » Fri May 31, 2019 4:25 pm
    I've been looking for this feature for years and I am very stoked that a simple terminal command will display it. Would be killer to have it as a native option in MM.
    Re: FPS Display
    by franz » Mon Jun 03, 2019 4:32 pm
    you're right we should include it officially in the preferences, since I'm giving you the info anyway ...
    caneron
    Re: FPS Display
    by caneron » Wed Jun 05, 2019 4:08 pm
    Hell yeah Franz!
    Re: FPS Display
    by franz » Mon Jan 18, 2021 6:12 pm
    included in 4.0, click the little gear button on the right side of the output preview
