Using surfaces with LEDs
  • afterglo
    by afterglo » Sun Dec 02, 2018 10:30 pm
    So I'm using the demo and would like to use the full version to do some LED pixel mapping but I have some questions about things that don't make much sense to me right now. Is there a way to use the surfaces feature with the LED fixtures? I can only seem to generate cues for the fixtures and would like to be able to use the blend modes and stuff with the LEDs.
    Is there a way I just can't figure out to apply that to the LEDs or is it really only possible with projectors? Are there any good tutorials on this because I'm having a really hard time finding anything good.
  • afterglo
    Re: Using surfaces with LEDs
    by afterglo » Mon Dec 03, 2018 6:55 am
    Possible or no? one of the main reasons i would use madmapper is to use it as an easy effects generator + pixel a=mapper. is definitely significantly less attractive if i can't blend and layer the materials + videos in the application.
    Also if anyone has connections to solid tutorials for this type of stuff im really struggling to find it.
    by mad-matt » Mon Dec 03, 2018 10:03 am
  • afterglo
    by afterglo » Mon Dec 03, 2018 7:49 pm
    Beautiful exactly what I needed. Thanks for the links.
