Auto-generate Cue/Scene Thumbnail
  • yirehmail
    by yirehmail » Mon Dec 03, 2018 4:51 pm
    Hi Madmapper Team!
    I have found myself very often using madmapper as a media player for our events. However it's hard to visually see which cue is which video. I know it is possible to load custom images as thumbnail, but it would be so much more time saving if it could auto-generate thumbnails.
    Re: Auto-generate Cue/Scene Thumbnail
    by franz » Mon Jan 07, 2019 12:25 pm
    already possible.
    you can change the color, rename the cues, add comments and specify a custom thumbnail,
    all from the parameters button (the little gear) of a cue
  • yirehmail
    by yirehmail » Tue Jan 08, 2019 4:42 am
    I know it is possible to do it manually, but it would so much more convenient if the system would auto-create a snapshot of the cue and put it on the thumbnail.
    already possible.
    by franz » Tue Jan 08, 2019 7:07 pm
    the problem is that cues can contain parameters that are not graphical, so in some cases, what should we snapshot exactly ?
    the option is left to the user: load a specific image
