Re-Trigger Animation FX via MIDI
  • koochey
    by koochey » Tue Dec 04, 2018 3:42 pm
    Hi - i would like to know if there is any option to Re-trigger the FX Section in Modul8 ?
    Every Time i switch the layer on/off the Animation is still running in the background.
    I need a solution that the animation is restarted via an incoming MIDI Note - a so called One-Shot Trigger.
    Is there any Module out there or can anybody help ?
    thanks
    txo!?
    Re: Re-Trigger Animation FX via MIDI
    by txo!? » Mon Dec 10, 2018 8:54 pm
    Hi
    I'm not sure what you mean with "restarted", but this shouldn't be difficult doing with the module editor.
    Look at the documentation on how to make modules without coding, no need at all. Create a new module, drag a button and assign a keyword for the layer on/off on map1 and a keyword for the fx on/off in the map2. Picking them on UI is so easy.
    You could do this for each layer or per selected one.
    You could not map a midi note to two different controls directly, but doing a module that targets both is easy and then you could map a single note to that module button.
    Hope it helps :)
  • Martyhiect
    Re Trigger Animation FX via MIDI
    by Martyhiect » Tue Dec 11, 2018 7:50 pm
    That sounds really stressful. Is there someone you can speak to before you make any decisions as to move or what to do?
