Best led single pixel hardware for madmapper
  • Fabioquiet
    by Fabioquiet » Wed Dec 05, 2018 2:28 pm
    Hi
    i have to build a structure with 8 towers, and each tower has 36 meters of strip led single pixel RGB and the totals are 2160 led RGB for each tower and 17,280 led RGB in total. So a lot of pixel. At the moment the best solution that i found is the PixLite 16 Long Range MkII Controller : https://www.advateklights.com/pixlite-control/ with 8 PixLite Long Range Receiver.
    It arrive to 16,320 RGB pixels, and in case i'll try to adapt the project to this number.
    Do you think that can I control all these single led information with madmapper? Is it too much for MM? And do you think that a minimad is able to control all these information?
    Otherwise do you have other suggestions for other hardware? I readed all the topic about led in the forum and i didnt find any other good solution for my project.
    I was thinking also to have an different driver board for each tower but it will be more expansive, but at this moment i'm open to any other possibility.
    And i have also the problem that i need this hardware in 1-2 weeks maximum.
    I hope someone can help me.
    thanks
  • Fabioquiet
    Re: Best led single pixel hardware for madmapper
    by Fabioquiet » Tue Feb 19, 2019 1:06 pm
    Update:
    i Bought this hardware and i tested it with 9 meter of strip led, and it is working very well. In 2-3 weeks i will test the board with the maximum of leds and i will write here the resoult.
    yo
  • Fabioquiet
    by Fabioquiet » Wed Mar 20, 2019 4:19 pm
    Update:
    i tested the board at 100% of capacity (16320 led RGB) with strip led RGB SK9822, and it worked perfectly with 1.2 / 1.4 clock parameter. at 2.9 clock the light was more fluid but i had problem with less then 100% of luminosity.
    Yo
  • CrystalAaron
    by CrystalAaron » Mon May 11, 2020 5:09 am
    Have you ever used SK9822-A led strip?It's a fastest frequency speed led SK9822-A 1, PWM frequency can reach 27KHZ.APA102 PWM frequency is 20KHZ,SK9822 PWM frequency is 4.7KHZ. it have Data and Clock signal input and output , which make the signal transfer more stable ,then it can be Anti-signal interference without using capacitor.
    Does it have the same way to be controlled by Madmapper?
    by mad-matt » Mon May 11, 2020 11:03 pm
    You can control any LED type with MadMapper if you have a LED driver that handles ArtNet or sACN (as input) and that can controls those LED chips.
