Scenes: when replacing video the play length can't be adjusted
  • Teunkneus
    by Teunkneus » Fri Dec 07, 2018 5:47 pm
    I've noticed that when I made a pre-built of a mapping, that when I have a certain clip in a scene and replace it, it's impossible to adjust the length to the newer longer video. Say the old video is 1:05 and the new clip 1:10.
    It just cuts off at the end off the previous clip so the new clip gets an stop at 1:05 instead of 1:10.
    Have tried to update with the new clip and adjust the loop length to 1:10 but it just says the length but when played it's still cuts of at the timing of the previous video 1:05.
    Do I miss something? or does this mean I have to make a new scene when the new video has a different length.
    Re: Scenes: when replacing video the play length can't be adjusted
    by mad-matt » Mon Dec 10, 2018 12:56 am
    We fixed something in 3.6.2 about it if I'm not wrong. Which version are you running ?
  • Teunkneus
    by Teunkneus » Thu Dec 13, 2018 1:44 pm
    Thnx I was running 3.5.2 so I will test it in 3.6.2 when I have some time.
