Scenes Not Playing Properly
  • madden
    by madden » Fri Dec 21, 2018 3:09 am
    Hi!
    I'm new to Madmapper and cannot get my scenes to automatically play in a loop one after the other. It skips scene one, plays 2 and 3 seamlessly and then stops.
    I have tried:
    Inspector, Restart, Check Value
    Cue Scheduler - Automate - Switch On Movie Loop End
    Auto Play set to "If any movie is playing, switch when a movie loop finishes.
    I am not using cues; however, I tried moving the media into cues and couldn't get that to play either. Any idea what I am missing?
    Thank you!
    Tim
    Re: Scenes Not Playing Properly
    by mad-matt » Sat Dec 29, 2018 11:48 am
    Is MadMapper up to date ?
    Could you PM me your project file so I check if I can understand or reproduce your issue ?
  • Teunkneus
    by Teunkneus » Thu Jan 03, 2019 4:35 pm
    Check if you set everything that you don't save!
    I've had issues when I saved a project it would change settings in scenes to default again. (video's would loop again or don't start etc.)
    So my workflow was like:
    Build project
    set al scenes or cues
    Save
    set all settings for scenes and cues again
    make a change
    save
    set al settings again for scenes and cues
    Apparently it should be fixed with new version, but maybe you have found the issue again ;)
