Trouble shooting with Restart Movie Function
  • VJ Hieros Gamos
    by VJ Hieros Gamos » Sat Dec 29, 2018 9:15 am
    I used MADMAPPER 3.6.2. in Ouagadougou for the "Dialogue de Corps" Festival. But when I was in performance, the "restart movie function" allways send the last frame where it was stopped...
    I explain : I stop at the 42 seconds of the movie. When I use the cue, it put FOR ONE FRAME sounds and picture of the 42 seconds, and THEN read it from the first beginning of the movie.
    So I get a dirty "video flash" in my show, very inconfortable for me, when the cue was pressed. And after everything's back to normal.
    Is there a fix for this problem ?
    Thanks for the team and all the work you do.
    Joyeuses Fêtes de Fin d'Année !
    Re: Trouble shooting with Restart Movie Function
    by mad-matt » Sat Dec 29, 2018 11:38 am
    You can check in the inspector if Loop Start and Loop End are stored for this visual ? Also check that Position is not stored (in case you added it manually in Edit Cues mode)
    If that's not the case and you know a way to reproduce it, let me know.
    If you're on macOS, let me know if you're using the AVFoundation player, in which case deactivated "Enable hardware acceleration" might help.
