Arri skypanels on madmapper
  • yonital
    by yonital » Fri Jan 11, 2019 5:27 pm
    hello
    i am trying to set up the arri SkyPanel on madmapper
    can anyone help with custom fixture dmx process ?
    thank you
    yonatan
    Re: Arri skypanels on madmapper
    by mad-matt » Sun Jan 13, 2019 10:48 pm
    Which model exactly ? We can post the fixture definition file, it's easy to do if you have the DMX patch PDF or webpage.
  • yonital
    by yonital » Mon Jan 14, 2019 11:14 am
    hello i need for all the SkyPanel models 60c,120c &360c here is arri pdf
    there is a way to control each light engine in the same fixture (dmx mode 24 for 8 bit or mode 25 for 16 bit )
    https://www.arri.com/resource/blob/6595 ... 8-data.pdf
    thank you for your help
    by mad-matt » Tue Jan 15, 2019 11:15 pm
    I attached a fixture definition for Arri SkyPanel in Mode 1 with Extended Color Control activated in the DMX Settings of the panel. I haven't made the simplest but the best: when using red, only the red LEDs will light up, while when using a grey scale, only white LEDs will light up, when using a color between red and white, both red and white LEDs will light up half power. So when using a white, you get a pure white, not a mix of red, green and blue leds.
    Let me know if everything is ok with it.
    Arri SkyPanel Mode 1.mmfl.zip
    (910 Bytes) Downloaded 1156 times
  • yonital
    by yonital » Wed Jan 16, 2019 8:29 am
    thank you so much, i will try it out soon in the studio
