in Release 3.1
  • claude steiner
    in Release 3.1
    by claude steiner » Fri Jan 11, 2019 5:43 pm
    Hello aeverybody here
    I am using 3.1 instead of the Beta Version, and have something doesent work properly:
    If i use Transformer / Matrix make some programming, save it and reopen the same file
    the Transformer is not enabled. I always have to manualy enable that button in every Slot.
    I also kill the pref files but still the same!
    Can you give me a advice?
    Thanks, Claude
    Re: in Release 3.1
    by MADben » Mon Jan 14, 2019 3:19 pm
    Hi Claude,
    Could you please contact the garageCube team through this page : http://www.garagecube.com/contact/
    As you will be put in contact with the team who will be able to help you,
    Thanks
