Visualizer for Madlights possible?
  • Mjason
    by Mjason » Tue Feb 05, 2019 9:26 pm
    I am currently programming approximately 80 LED-fixtures by Garagecube and I was wondering if there is any way to Visualize the artnet output as i do not have the space to set up all the fixtures physically here.
    Re: Visualizer for Madlights possible?
    by franz » Wed Feb 06, 2019 3:47 pm
    /tools/dmx monitor ?
  • Isocellator
    by Isocellator » Fri Jan 08, 2021 10:33 am
    I would also like a DMX visualizer. You can watch the raw data with the DMX monitor, but it is not a visualizer...
    It would also be really nice to place virtual fixtures over a proper transformable quad or an output ...
    by franz » Mon Jan 11, 2021 7:07 pm
    I personnaly do this with a custom raytraced material. I don't previz the artnet output directly, rather the texture input (using a syphon loopback for instance).
    It might become tricky to place the LED bars programmatically if your setup goes wild in terms of shape, tho'.
    (Another option is to create a 3d object with correct uv mapping, load it up in MM then apply your content on it)
    Screenshot 2020-11-09 at 12.28.02.png (404.24 KiB) Viewed 3688 times
