using OSC to remote MM on the same machine as client
  • simonegiusti
    by simonegiusti » Fri Feb 08, 2019 11:24 am
    I would like to remote MM using ShowCueSystems or another software installed on the same machine.
    How will I configure it ???
    OS: Windows
    Re: using OSC to remote MM on the same machine as client
    by mad-matt » Wed Feb 13, 2019 11:53 pm
    There's no problem about it. You can set IP to 127.0.0.1 and setup the same port number in MadMapper / Preferences / OSC and in your control software (as the output port). If your application also supports OSC input, be sure to setup a different port for this one. Only one application is supposed to open the same port on the same machine (at least you avoid possible issues doing so).
