Please activate MadMapper to install this material
  • TinyMapper
    by TinyMapper » Sun Feb 10, 2019 2:47 am
    Hey all,
    I just recently bought the one month version of MadMapper and had a stroll through the material library.
    Unfortunately when I try to install one of the many public materials I get the message: "Please activate MadMapper to install this material".
    I downloaded the version from yourspace and have entered the key that I was sent by MadMapper. I can store my project so I am pretty sure that I am using the full version (and not the still installed Demo by accident : P ).
    Is there another step I need to take before fully activating this product?
    TinyMapper
    Re: Please activate MadMapper to install this material
    by franz » Wed Feb 13, 2019 10:28 pm
    to download a material you have to login with your forum account.
    there's a login/logout button in the material library
  • niccab
    by niccab » Sat May 11, 2019 8:18 am
    Hi there, I'm experiencing the same issue. I downloaded the most recent version of MadMapper from yourspace, entered my serial, logged into my forum account in the material library, and still get this error message "Please activate Madmapper to install this material." Let me know if I'm doing something wrong!
    by MADben » Sun May 12, 2019 6:49 pm
    you should contact the garagecube support
    http://www.garagecube.com/contact/
    we can then help you figure out where the issue comes from
    by mad-matt » Mon May 13, 2019 12:25 pm
    You should try to deactivate / reactivate MadMapper in this machine, seems it's not registered in the database...
  • Yorch666
    by Yorch666 » Thu Nov 19, 2020 2:03 pm
    how? de-authorize mad mapper on my computer??
