Thanks for the update Franz, i will check this out, at the moment i have a "scarlet 2i2 focusrite" at home but that didnt work...to be honest, try to borrow a dedicated sound card from a friend, and test it in your setup.
I have random problems when using the built in sound card (the realtek), and the problems were magically gone when using the dedicated soundcard.
Hi Franz,the focus rite scarlett should work without any problem.
let me summarize:
you have the scarlett correctly installed and plugged.
you send sound signal into the scarlett.
under windows sound recording pref. panel, you see your input but no actual volume.
am i right ?
