ColorPatterns generator not working on Windows machine
  • ttwwooyypp
    by ttwwooyypp » Mon Mar 11, 2019 5:04 pm
    I built out a project file on a Mac that utilizes the ColorPatterns generator. When I open the project on the PC which will actually be running the show, ColorPatterns (and all the other generators) appear as OFFLINE. Does anyone have a solution for this?
    The PC in question is a Microsoft Surface running Windows 10.
  • ttwwooyypp
    Re: ColorPatterns generator not working on Windows machine
    by ttwwooyypp » Mon Mar 11, 2019 5:12 pm
    Heads up.. just found the solution via another post which was to Open the Madmapper application and then load the project file instead of launching MM via opening project file. Reliable workaround for this bug.
  • florafaunavisions
    by florafaunavisions » Tue May 21, 2019 10:56 am
    I've got the same problem on our Windows machine but it also affects the Control List. The GlobalBPM Control is not available if the Project get's opened at startup or via opening the project file.
    Loading the file via MadMapper is not possible for us since the project has to work automatically after startup. Is there another workaround or bugfix for this problem?
