Quick short question. Sorry if it's been discussed before...
Can I assign more than one FX on a surface? Seems like selecting new FX type disables the earlier one.
Same thoughts here exactly.Thanks for your reply. It would be nice to have a contrast, brightness & saturation as a separate from FX, because most of the time a little tweak is necessary in location. IMO they are lot more usefull than RGB sliders that are at the moment separate from FX. I'll write a suggestion post separately from this to the suggestion forum.
Where'd it go in 4.1?!an fx stack is something we want for a longtime.
meanwhile, have you tryied the "Multi FX" already ? in mm 4.0 ?
Users browsing this forum: No registered users and 60 guests
