Master Transition Time
  • freadZdead
    by freadZdead » Sun Mar 24, 2019 12:03 am
    Hi again,
    This one is about having the possibility for a mappable master transition time - from:
    - one scene to the next,
    - from one cue to the next, but also:
    - for any change made in the live programming/value adjustment of materials (when made manual, obviously not when made via any MIDI/OSC inputs)
    It would be great if this came with something like an enable toggle and when enabled will override all programmed or default fade timings.
    Does this exist? Otherwise I'll put that one onto a wish list as well .
    Cheers,
    Freddy
    Re: Master Transition Time
    by mad-matt » Mon Mar 25, 2019 12:37 pm
    Hi Freddy,
    No it's not possible at the moment.
    I'll add this feature request to our list.
    Thanks for the feedabck!
