Extra UVs on 3D Surface Object
  • syntheticlives
    by syntheticlives » Tue Mar 26, 2019 12:40 am
    Hi, I am trying to wrap a UV map textured around my 3D surface object in Madmapper. In C4D, the texture wraps perfectly to my model. However, when I import the model and texture into Madmapper, it doesn't wrap correctly and it seems like extra geometry has been added to my UV map somewhere along the process. You can see in the attached screenshots that my UV map on the right side of the screen in C4D looks find and the same map on the left side of the screen in Madmapper looks way different.
    Anyone know what's going on?
    Screen Shot 2019-03-25 at 6.30.52 PM copy.jpg (116.2 KiB) Viewed 2753 times
    Screen Shot 2019-03-25 at 6.30.49 PM copy.jpg (93.55 KiB) Viewed 2753 times
    Re: Extra UVs on 3D Surface Object
    by franz » Wed Mar 27, 2019 3:06 pm
    it looks like your uvs have been exported incorrectly, if exported at all.
    Have you unwrapped your uvs in C4d ? there doesn't seem to be any uv modifier on your object...
    (but I'm not c4d pro)
