Using encoders with MIDI Controller
  • AEK_98
    by AEK_98 » Sun Apr 07, 2019 10:08 pm
    Our task - When switching scenes and cues, get synchronization encoders of midi controller(Novation ZeRO SL MkII) with the values set for these parameters in Mad Mapper. In the preferences MIDI feedback device selected. But this is not enough - when changing scenes, the encoders is not set to the position of the corresponding parameters.
    What could be the solution to the problem?
    Best regards,
    Andrey.
    Re: Using encoders with MIDI Controller
    by franz » Tue Apr 09, 2019 10:23 am
    midi feedback should work with scenes and cues. which parameter are you missing ? all of them ?
    by MADben » Tue Apr 09, 2019 3:44 pm
    it should work indeed
    did you properly setup you midi device in madMapper?
    (do you have the same type of issue with your controller and other madMapper functions than scenes and cues?)
  • AEK_98
    by AEK_98 » Wed Apr 10, 2019 12:46 am
    When switching a group of effects(multiple FX) active cue, can Madmapper restore the values on the encoder knobs from the previous state of these effects?
  • AEK_98
    by AEK_98 » Sat Apr 13, 2019 1:03 pm
    No solutions to our problem? :(
