image resolution issues
  • landmark_jmh
    by landmark_jmh » Sat Apr 13, 2019 3:26 am
    Hi, I just purchased a miniMAD and watched the tutorials multiple times. When I export my project, which is a static image, it keeps downgrading it to 640x480 which looks very pixelated. I am using a 1280x800 projector and in the MAD mapper software the projector resolution is set to 1280x800 and the original image resolution is 1280x800. Every time I export and run the miniMAD it shows me a 640x480 image. Is there a way to show a higher quality image on the miniMAD?
    Re: image resolution issues
    by Pierre Guilluy » Tue Apr 23, 2019 3:13 pm
    Please check the actual resolution of the exported image in the mapping folder of the SD-card.
    My guess is that the miniMAD, for some reason, cannot switch to the resolution & frequency you've selected when exporting (1280x800) and switches to the default resolution (640x480).
    Don't you plug or power the projector after the miniMAD started?
