mutliple projector
  • makio64
    mutliple projector
    by makio64 » Wed Apr 17, 2019 12:38 pm
    I love madMapper but I was wondering if it was suitable for more than fews projectors, for example for 20 projectors.
    Is there any way of making it as a server and dispatch it to multiple computer, each controlling fews projector ?
    I thought about making multiple Spout exit but I feel it might not work.
    Thanks in advance.
    D
    ScottElliff
    Re: mutliple projector
    by ScottElliff » Fri Apr 19, 2019 7:54 am
    Posted by makio64
    https://cheapessaywriter.net
    Thanks in advance.
    D
    Hi there,
    I tried mapping with 3 projectors. Because previously, when I was using only 2, I had places where there was almost no definition. So I created the 3D surface for each projector and then calibrated them. Last year I tried Isadora, but then decided to switch to MadMapper.
  • Teunkneus
    by Teunkneus » Mon May 06, 2019 10:00 am
    Thanks in advance.
    D
    On a single PC i managed 4 projectors, and did one with 8 and used 2 pc's.
    I don't know what you want to create but I triggered with OSC and it worked quite well to make everything sync.
    So I guess 20 will be possible but i think you would need 5 pc's and 3 licenses. Please let us know how you fixed it.
    by franz » Tue May 07, 2019 4:39 pm
    with one datapath hardware, you could easily drive 8 projectors per graphic card.
    so that's minimum 8 proj per computer.
