MINIMAD LIGHT error
  • angusmuirdesign
    MINIMAD LIGHT error
    by angusmuirdesign » Mon Apr 22, 2019 9:39 am
    I have been having many issues recently exporting to MINIMAD (artnet)
    The problems start a month or so ago, after using the software and exporting seamlessly many times.
    Everything works perfectly from MADMAPPER to artnet devices, then export shows to SD and then no output and red light flashes.
    Have tried it on new minimad with supplied SD cards, have flashed new ones, have tried old ones,
    Have updated madmapper and sd cards in the recorder.
    Have tried artnet, uni cast, direct ip, sacn all to no avail.
    Love some assistance! We use them all the time for so many of our artworks and no have a 5% strike rate and can't rely on them.
    please help!
    Re: MINIMAD LIGHT error
    by MADben » Mon Apr 22, 2019 11:01 am
    flashing the sd card (with the image disk from yourspace) solves 99% of the minimad's issues...
    regarding all you did/tried it may be a device issue,
    please contact the garagecube team through this page : http://www.garagecube.com/contact/
  • angusmuirdesign
    by angusmuirdesign » Tue Apr 23, 2019 8:32 am
    Thanks,
    I am going to try it from my mac tonight.
    It does seem odd that even the 4 new MiniMads had issues - feels like maybe it is a laptop issue.
    Ill let you know thanks.
  • stphntylr
    by stphntylr » Sun Jun 30, 2019 7:58 pm
    Curious if you ever resolved this as I am having the exact same issue. Multiple minimads tried, multiple sd cards, Mac/pc exports.
    by franz » Fri Dec 06, 2019 5:24 pm
    red flashing light means activation.
    connect a screen and activate your card.
    by Pierre Guilluy » Fri Dec 06, 2019 11:03 pm
    FYI, the miniMAD will require activation (red, yellow, blue buttons press) every time you use a SD-card that was used in another miniMAD.
    I advice you label each SD-card to match its corresponding miniMAD so you don't have to activate anymore.
