Scenes and cues fade priority
  • Gildas
    by Gildas » Thu Apr 25, 2019 1:58 pm
    I have difficulties to manage correctly fade times on scenes and cues.
    I want to construct scenes with differents fade times for each cues (cue 1 : fade 5 sec / cue 2 : fade 10 sec...), but it's the scene fade parameter who has priority on fade times instead of the fade times of the cues.
    Is it possible to ignore fade time of the scene ?
    Thank you
    Re: Scenes and cues fade priority
    by franz » Tue May 14, 2019 9:53 am
    when a scene and a cue are on the same COLUMN, the scene has priority.
    don't use scene on the same columns as cues - use only cues for instance -
