Adding more effects Mad Mapper
  • rikimazza
    by rikimazza » Sun Apr 28, 2019 7:09 pm
    I apologize if the questions has been posted before, but I could't find the thread on the forum.
    Is there a way to import more Fx Type to Mad Mapper? I builded some Quatrz effects, but they behave like materials overlaying the quad below. I was wondering if there is a way to increment the Fxs list located in the quad inspector so that I can actually modify the image with more fx choices..
    Ciao Riccardo
    Re: Adding more effects Mad Mapper
    by franz » Tue May 07, 2019 4:37 pm
    custom FX are planned for the future.
    you can already program yourself some, but it is undocumented and unsupported at the moment.
    by mad-matt » Tue May 07, 2019 10:59 pm
    ISFs effects can be used (if they don't use render passes)
