static IP address
  • 235media
    static IP address
    by 235media » Wed May 08, 2019 1:24 pm
    Hi, is it possible to set a specific static IP address on miniMAD?
    Re: static IP address
    by mad-matt » Thu May 09, 2019 8:52 am
    For the miniMAD Light yes.
    For the miniMAD video I don't think so, if the network is DHCP enabled it will use the DHCP address, if not it will auto-assign itself an address after having looked if any other miniMAD on the network is not using this one. If you have a router with DHCP on the network, you should be able to tell the router to assign a defined IP to the miniMAD (giving him the miniMAD MAC Address and the desired IP)
