Smooth video playback ?
    Just_Deweak
    by Just_Deweak » Sat May 11, 2019 3:23 pm
    Hi all,
    I can’t have a smooth playback with H264 files or generated textures or anything going out of MM, does someone has a clue ?
    Here is my setup :
    MSI laptop with 16GB Ram and a Nvidia RTX2060 chipset
    Graphics card set to 50Hz to match the 1080p @ 50 EDID from my Barco E2 high-end switching system (feeding a LED wall and LCD screens, all set to 50 Hz).
    With H.264 MP4 files encoded at 10Mbps at 25 or 50fps, MM is unusable since playback isn’t smooth at all. Locally (on my computer’s screen), I can have a smooth playback, though.
    Same issue with the FHD @ 50Hz outputs of my Matrox triple head DP...
    I’m a bit puzzled since I’d like to use MM as a light substitute for a Modulo Pi system sometimes, and this lag makes it a bit unusable...
    Re: Smooth video playback ?
    by franz » Tue May 14, 2019 10:00 am
    on my MSI laptop MM is running flawless.
    Did you test madmapper on another computer ?
    What version are you using ? Did you check "use hardware acceleration" in the movie ?
