M8 Compositing handles alpha values poorly
  • geoffmatters
    by geoffmatters » Fri May 17, 2019 2:11 pm
    RGB values of pure white over solid pure white should render to pure white regardless of the alpha values of the upper layer.
    However in M8 a pixel which is RGBA 255,255,255,127 will render grey when composited over white.
    Attached is an example showing a PNG with white shapes with antialiased edges over a solid white layer. M8 renders it with a dark outline. Photoshop renders the same thing as pure white.
  • geoffmatters
    Re: M8 Compositing handles alpha values poorly
    by geoffmatters » Fri May 17, 2019 2:14 pm
    I can't attach anything because "Sorry, the board attachment quota has been reached."
  • geoffmatters
    by geoffmatters » Fri May 17, 2019 2:22 pm
    Repros with 2.92 as well as latest 3.0 on my MBP with AMD Radeon R9 M370X 2048 MB
  • geoffmatters
    by geoffmatters » Sun Jun 14, 2020 8:16 am
    Here is white composition over white resulting in grey pixels.
    It is quite bad that the basic math of compositing layers is not correct. I had been bothered by strange shadows and edges many times over the years, probably as the result of this bug.
    M8 Compositing Bug.png (240.71 KiB) Viewed 10490 times
