Here are the Artnet Node Settings, Port Settings and MM settings.
The same configuration works in Resolume Arena 5 (Please don't hate me, LOL)
What am I doing wrong here?
I switched the node to DHCP and it popped right up with all the universes intact. By the way, the LeDMX4 Pro is a great value, 4 Artnet to SPI universes and one 3 wire DMX universe for $130 USDHi,
The selected network interface IP address is weird. I think you should just select the correct network interface in MadMapper Preferences / DMX output.
Also when debugging, disable unicast so it removes one possible problem. When it work with broadcast, then go to unicast if you have many universes.
