MadMapper 3.7.0 Release
    by MADben » Thu May 23, 2019 10:01 am
    Dear MadMapper users,
    we're glad to announce you that we just released the official MadMapper version 3.7.0,
    You can download it as usual on the yourspace page : https://madmapper.com/yourspace/
    This new version introduces cue auto play settings per column, major improvement with AMD driver on Windows, optimised HAP decoding, multiple oscillators and many other improvements and fixes!
    MadMapper 3.7.0 Release Note :
    ADDITIONS
    + Cues:
    Added autoplay settings per column
    Added an option to set cue thumbnail from one of the visuals it's referencing
    Restart media is set to ON by default (use cue inspector to deactivate)
    + Native support of HapQ Alpha & optimized HAP decoding in general
    + Oscillator: replaced Master Oscillator by an Oscillator module that can be created as many times as wanted, as well as a 2D Oscillator (projects made with previous releases will still work like before)
    + Added drag&drop possibility in textual Media List
    + NDI output: added a checkbox to enable alpha channel in stream (compressing with alpha channel is slower and useless in most cases)
    + DMX output: possibility to use media Alpha channel in fixtures (using expressions) and to ignore alpha channel for R,G,B,W,L,C,M,Y,K values (useful to driver RGBW LEDs from a RGBA movie or syphon/spout stream)
    IMPROVEMENTS
    * Major optimisation on Windows when using multiple outputs with AMD graphics card
    * Various optimisations
    * When dropping a visual (file or internal drag) to the preview, create a quad surface with the visual where we released the mouse
    * Updated to latest NDI SDK (3.8 )
    * Updated to latest Canon SDK
    * Improved crash reporter on Windows
    * Improved audio spectrum reactivity (higher update rate and lower delay)
    * Added bpm_phase_sync parameter to TimeBase generator/filter (for user materials)
    FIXES
    - Fixed a possible issue when reloading a file at startup
    - Cue auto-play “Play next when movie loop ends” was sometimes not working when movie audio track is active
    - It could happen that movie was shorten when reaching the end (depending on the codec & how the movie was created)
    - Fixed issue with Folder Player last frame
    - Fixed possible issue when connecting / disconnecting screens
    - ArtNet Unicast: fixed possible issue when polling for devices from preferences
    - ArtNet Unicast: fixed possible issue when several devices are listening to the same universe
    - Fixed Kinect Masker (macOS only)
    - Fixed LED Scanner generated fixture size in case of single pixel fixtures
    - Solved an issue on Windows when ASIO driver is selected in Audio preferences
    - Fixed an issue when cueing Solid Color generator
    Enjoy!
    The MadTeam.
  • dougatron
    Re: MadMapper 3.7.0 Release
    by dougatron » Thu May 23, 2019 7:43 pm
    Hi
    This release looks great! Would like to ask if there's any reason you've switched from a disk image to an installer package for the mac version? Being an installer it's now not possible to install if you don't have admin privileges 😕
    Thanks
    by franz » Mon Jun 17, 2019 11:01 am
    we switched to a pkg installer on the mac because we want to support macos from 10.9 to 10.14 for madmapper 3.xx branch.
