Dual GPU Quadro p2000, win10
  • Chuchocaro
    by Chuchocaro » Wed May 29, 2019 8:49 pm
    Hi, I'm building a video mapping project on a 360 wall, with 8 fullHD video projectors, so the computer I want to build can have two Quadro P2000 video cards to have the 8 video outputs with MadMapper?
    I would appreciate if someone can help me or that someone has experience using two video cards in windows 10
    Re: Dual GPU Quadro p2000, win10
    by mad-matt » Thu May 30, 2019 11:08 am
    Yes it should work. Note that you shouldn't connect both cards with SLI (because only the outputs of one card are usable in this case)
    caneron
    by caneron » Fri May 31, 2019 11:23 pm
    The next question is about using 2x P4000s and 8@4k. The computer specs support it but it runs at like 8 FPS in MadMapper. 8@1080 works fine. Any ideas?
