Música
  • Principiante
    Música
    by Principiante » Sun Jun 02, 2019 2:02 am
    Hola,
    Se puede añadir música a Madmapper?
    Gracias!
    manoly
    Re: Música
    by manoly » Wed Feb 12, 2020 12:48 am
    Pues parece que en las nuevas beta ya incluye esa opción
    light up your space, share the path
    @missvisuales
    Re: Música
    by MADben » Wed Feb 12, 2020 10:39 am
    Yes indeed : there is now a proper Audio module player with MadMapper v4.
    The BETA is available on the Yourspace page and free if you own a v3 license. Give it a try!
    Otherwise you can actually use a video including your Audio file (use a video editing software to create it) and mask it in order to only use the Audio track
