Arduino LED-Strip
  • blaQw1nd
    Arduino LED-Strip
    by blaQw1nd » Mon Jun 03, 2019 12:52 pm
    Hey Guys,
    I am currently trying to test MadMapper if that works for my projects. So I downloaded the trial version.
    I set up an LED stripe with APA102 LEDs and an Arduino nano and following the instructions.
    The test of the Arduion works.
    My problem is now following:
    If I want now to start with the setup of MadMapper in preferences at ArtNet I got no interface which is local host (127.0.0.1) and I think in this case I cant choose the out led device.
    Or does that not work because I got the trial version?
    Any ideas for me?
    Best regards,
    Chris
    Re: Arduino LED-Strip
    by mad-matt » Fri Jun 07, 2019 10:03 am
    You don't need to use localhost, you can choose whatever network interface. Using local loopback is just to avoid polluting a network with useless ArtNet packets. But if you just have a bunch of universes, no problem.
    Cheers!
