Modul8 + Korg nanoKontrol2 + MacOS Mojave
  • bandian
    by bandian » Mon Jun 03, 2019 8:34 pm
    Hi there!
    I've used Modul8 + Korg nanoKontrol2 in the past and everything was perfect.
    Now , after i updated the OS to Mojave, the korgControl stops to work and i suppose
    it has stopped to work properly just with modul8 because if i use it with other software (ableton Live, for example)
    it works perfectly.
    Did some have the same issue?
    Can someone help me?
    If not, can someone suggest me a valid low-budget midi controller that works with modul8 and MacOS Mojave?
    Thank you so much,
    Francesco
