Splitting a Movie in a few shapes?
  • Lablacklabel
    by Lablacklabel » Thu Jun 06, 2019 5:10 pm
    Hey there, i like the Software but i dont know if i am to stupid or does it really can not split an Movie or Image to a few, as example squares?
    So i thougt i make 8 squares in a row and let a little bit Space between and Group them and put a Media in that Group and the Image will be Shown as on big picture over all squares, but it just put the Image in each single square :(
    Is there and Option with madmapper? So just as example 3 screens horizontal with 1m Space between each screen, build this in mm and have a Movie Played over all screens with the Space between without loosing content (mask etc).
    Hope someone can Open my eyes
    Regards
    Lablacklabel
    Re: Splitting a Movie in a few shapes?
    by mad-matt » Fri Jun 07, 2019 9:42 am
    You have to move each quads in the input view to select the part of the media to be shown in each quad. If you rescale one quad, select all and right click the one you scaled correctly, you can choose "Resize All" in the popup menu. Then position one at the left, one at the right, select all again, right click and choose "Ditribute Horizontally" in the popup menu. They will now be all the same size and placed at equal distance. You can also align them using this same multi-selection - context menu.
  • Lablacklabel
    by Lablacklabel » Fri Jun 07, 2019 6:02 pm
    Oh, so easy.
    dammed thank you so much :-)
    May not Right here to ask, but is there an Option to Curve an added Line? If this would be possible theres no more i would expect^^
    best regards
    by mad-matt » Fri Jun 07, 2019 9:08 pm
    Curved lines will come... I can't officialize a deadline but it should not be too long !
Users browsing this forum: Baidu [Spider] and 51 guests
