Fast and best setting for export to minimad
  • fatcat
    by fatcat » Tue Jun 11, 2019 1:15 pm
    i know its .mov and h264.
    but when i export for minimad it reduce my files size. it take time to reduce and convert, and not just upload the files.
    i've uncheck Adjust movie resolution and Crop Media Files but it still reduce the my file size.
    when i open the mov files in the sd card in the mapping folder the format info it said:
    lavc56.60.100 +lib264
    is there any reference to follow for the right export or any utility that can help me to understand?
    my goal is to find the right export setting to have a fast "export to minimad" without any conversion.
    Re: Fast and best setting for export to minimad
    by Pierre Guilluy » Thu Jun 27, 2019 12:50 pm
    The miniMAD can playback H264 with 420 pixel-format only.
    You can produce your own file using your favorite transcoder (MadMapper uses FFmpeg).
    If you want to prevent MadMapper from reducing your movie, there's a dedicated setting in the Advanced tab.
  • fatcat
    by fatcat » Tue Jul 02, 2019 2:33 pm
    so if i use FFmpeg to encode my clip. with .mov container.
    mad mapper just copy it on the sd card. without any conversion?
