Input Crop and output crop is different
  • fatcat
    by fatcat » Tue Jun 11, 2019 6:41 pm
    Hi to all!
    i have a full HD clip. 1920x1080 px.
    in INPUT i crop my clip only 23 px on the top and 23 px in bottom.
    i export to mimimad with default setting
    i've leave checked Adjust movie resolution and Crop Media Files .
    the files on the SD card is 1600 x 860....
    where are they gone the other pixel? why minimad reduce my files size?
    Re: Input Crop and output crop is different
    by Pierre Guilluy » Thu Jun 27, 2019 12:47 pm
    Depending on various parameters, including the output and movie resolutions & framerates, MadMapper can downscale the movie during export to ensure a smooth playback on the miniMAD.
    You can deactivate this feature in the advanced parameters, but depending on your movie, the result may be less smooth.
  • fatcat
    by fatcat » Tue Jul 02, 2019 2:37 pm
    ok i understand. so it reduce also my files resolution?
    if MM it crop my files from 1920x1034 to 1600x860.
    a) it has the same quality with less pixel??
    b)...or less pixel and quality but a smooth playback.
    by franz » Thu Jul 04, 2019 7:34 pm
    it will have the less perceptual degradation while ensuring the smoothest playback
