Sending OSC Commands
  • andreichleb
    by andreichleb » Sun Jul 07, 2019 1:34 am
    As part of a cue column, is there anyway for MadMapper to SEND an OSC command to other devices on the network? In my example, when I trigger a MadMapper cue, in addition to starting the video playback, I want MadMapper to send an OSC Command which will then trigger the lighting console and also audio playback to start their respective sequences for the particular video. This is the opposite way of operating than normal as we would normally have the lighting console or Qlab trigger MadMapper, however, I am looking to bring the sequence programming and show control into MadMapper for a particular project.
  • renaud
    Re: Sending OSC Commands
    by renaud » Fri Jul 12, 2019 9:53 pm
    A workaround is to create a quad that is not visible, and control with OSC one of its parameter. Then active OSC feedback and this parameter will send its status thru OSC.
    by mad-matt » Fri Jul 12, 2019 11:08 pm
    We'll add this option in the future for sure.
