/cues/columns/start_by_name
  • renaud
    by renaud » Thu Jul 18, 2019 8:04 pm
    Dear MM Masters
    I'm using MM for years, but I'm working with the integrated cues system for the first time.
    Scenes are so usefull to make a memory of the whole setup, and cues are so efficient to save kind of presets.
    What I would miss at the moment is a name to each column. Because I'm launching columns through OSC, each column is a set of a few cues. And for the moment, columns could be triggered only by index. But when I add or remove a column, I must redo all my remote because column index has changed.
    Is it possible to add a name for each column and an OSC trigger for column/by_name ?
    Another thing that might be so usefull is an import/export function for scene and cues to/from a Json format. It would be an elegant solution to share cues/scenes with different projects.
    Re: /cues/columns/start_by_name
    by franz » Fri Jul 26, 2019 10:05 am
    +1 for custom naming of columns.
Users browsing this forum: No registered users and 46 guests
