OBJ File Too many lines
  • WernerC
    by WernerC » Wed Aug 07, 2019 3:03 pm
    I am new to MadMapper. I am trying to map a screen with a word written on it. The word is written in cursive.
    I have drawn the model in blender and have exported the obj and png files.
    I import the model into MM and the word itself seems weird. It looks like all the vertices are all linked to a single vertex on the same plane as the word... The cut outs on the word i.e. the holes in the O and g are filled and does not allow the FX to map to these points...
    If I then attenpt to create lines from the visible edges , MM says that the object has too many lines... What could be the problem and a possible cure for this? as a side note, my other models all seem to work fine.
    I have a limited licence for the software and the license will lapse in about 20 days... Hopefully it is only a user error that can be solved easily.
    Re: OBJ File Too many lines
    by franz » Wed Aug 07, 2019 6:36 pm
    did you try to export your model with ... less faces ?
